TallyPrime powered by AWS helps you to securely access TallyPrime and your business data anytime, anywhere. It’s enabled by a virtual machine dedicated to your business that is made easily available via our strong network of partners. So, you get greater flexibility to collaborate with multiple users working on the same data, at the same time.
Reliable | Secure | Simple | Affordable
You are familiar with the trust and simplicity of Tally products, and with AWS you will find expertise in cloud platforms. TallyPrime on AWS has been worked upon by teams at Tally & AWS to make sure it works for you anytime, anywhere. To know more about how AWS ensures high availability and security of data, you can visit this link.
If you choose to go with this option, all you need to do is talk to your Tally partner about it. They will lead the entire engagement from requirements gathering to implementation and even offer post-sales support. You don’t need to consult multiple vendors for your solution or for any concern related to it.
TallyPrime on AWS will be available to you at very affordable price points, worked out especially for the needs of your business.
Not sure which usage plan works best for you? Need to add more users? Busy month? You can seamlessly upgrade or downgrade your plan whenever you like, in a matter of minutes! A fully automated process will take care of your data and billing.
The solution works across Windows, Mac, and Linux clients when accessed through a Chrome browser even when you have different systems with general configurations of either 64 bit or 32 bit across users and across office-home
Got question? We’ll answer them for you!
TallyPrime 4.0 is the latest release of TallyPrime. It is packed with powerful features, designed to ensure seamless business management.
TallyPrime 4.0 comes with a host of features, including direct Excel import to TallyPrime, seamless sharing of invoices and documents via WhatsApp, and a powerful, intuitive dashboard.
Each remote user will receive the log-in credentials and URL to access TallyPrime remotely. Using the credentials, the users can either access it using a tool/client or from a browser
We have worked with AWS who are experts and leaders in the field of cloud technologies to offer you the best in terms of pricing, availability, scalability and security of your business data. For more info, visit elcom.digital
All you need to do is talk to your Tally partner and indicate your requirement. The partner will be your single point of contact, leading the engagement, suggesting and implementing the best solution based on your needs and offering you the required support.
No. You need to have an existing license or buy a single user or multi-user license of TallyPrime to access TallyPrime virtually.
