Compliance Calendar
Tally Search
Handling user's crucial business data was never easy, but Tally has been doing it effortlessly for years, thus becoming a top software trusted by millions. Efficient management of data is useful only when it is coupled with a robust mechanism of retrieving the useful information as and when required. Tally Prime has met this need with features like GoTo, Report Save, and Report Filters, enabling quick, data-driven decisions.
To further elevate our users' experience and make the data discovery process even faster, Tally introduces "Tally Search", a feature designed to help you search for the required information present anywhere in your company data at an unprecedented speed, eliminating the need to navigate to multiple places and providing highly relevant and precise results with just a click!
Key features
  • Precision and Speed
    Precision has always been a critical aspect of Tally, ensuring that users can quickly find the information that they are looking for.
    While precision is vital, speed is equally important. We understand that users need information instantly, so just type in whatever piece of information you have in hand and Tally Search helps to get precise and quick results ensuring a timely decision making for your business.
  • Adaptive nature
    Tally search will understand the nature of input and generate results that are best and most relevant for you. This means, you need not worry about spellings, the order of your words, or how you enter information. Just type in your query and get the best and most relevant results for you in a single click.
    Consider - You are unsure of the exact sequence of one of the printer's name in your stock items, just type in the keywords in any order you remember, for instance "Canon Pixma wireless printer compact" or "Canon Pixma compact printer wireless" and be rest assured, Tally Search will ensure you get the best and most relevant results quickly.
  • Search across companies
    Managing multiple companies in Tally Prime?
    Our powerful new search feature allows you to effortlessly find the data you need across all your loaded companies. Say goodbye to the hassle of finding the data in each company manually. With just one search you'll instantly get results from across all your companies.
  • One search bar, countless possibilities!
    Elevate your search experience! Effortlessly modify or add new queries without having to start over, allowing you to stay focused on what truly matters.
    Unlock the full potential of your searches with Tally Search.
  • Personalized Experience
    Trying to remember what was the input you gave to generate desired results?
    Stress no More!
    A history is maintained for all your recently searched keywords, which can be accessed and filtered as soon as your start typing, hence, an on-the-go experience to seamlessly select a past query and continue with your search.
like-thumb-icon
Like and encourage us to work harder and
bring wonderful capabilities to you
20 Likes 12 Comments
Tally to Tally Migration – Zero Downtime
New Tally to Tally Zero Downtime Migration gives you a quick and easy way to move to a newer version of Tally from any earlier Tally versions starting from Tally 4.5. Users can continue working in the existing version while migrating the data to a newer version of Tally.
Key features
  • Concurrency- Concurrently work on Tally data while it migrated to a newer version.
  • Pause and resume functionality- You can pause and resume your migration job if needed.
  • Resume from point of failure- Your migration can be resumed from a point of failure for e.g the system got shut down during migration, the user can continue from where migration was stopped.
  • Resolution Frame- Migrate data with errors successfully and use the resolution to fix the data issues at a later stage.
  • Multiple company migration– You can select and migrate multiple companies' data from a single screen.
like-thumb-icon
37 Likes 15 Comments
Auto Backup
Ensure Business Continuity with Reliable Cloud Backups
Since financial data is integral to daily business operations, implementing a robust, automated cloud backup solution can mitigate the risks of data loss from unexpected technology failures.
Key Features:
  • Secure Cloud Storage: Store backups on Tally's secure cloud infrastructure, offering superior protection against hardware failures, fires.
  • Automated & Scheduled Backups: Schedule backups at your desired frequency
  • Flexible Restoration: Easily restore lost or corrupted data to any point in time, regardless of location, with both on-site and off-site backup versions available.
  • Exception Notifications: Receive real-time notifications for any backup issues, facilitating prompt action and minimizing downtime.
like-thumb-icon
61 Likes 41 Comments
TP on AWS – Digital Signature
In TPonAWS, we have allowed our customers to access all the features of TallyPrime by securely anytime, anywhere. Now, by enabling the digital signature integration feature in Tally Prime on AWS, we offer businesses like yours to sign the vouchers and reports document while you Export/ E-mailing documents as PDF and Saving documents as PDF while printing.
like-thumb-icon
22 Likes 9 Comments
